I’m trying to install OSMC on a Raspberry Pi 3 with a 32GB microSD card. I have tried both the Windows installer(on SD card) and writing images 2016.05-1 and 2016.06-2 with Win32DiskImager. Every time I plug the SD card in the RPi it start formatting the device, and I end up with “Error: Can’t mount root”.
The SD card is a class 10 card that I have successfully used several times with different distributions before. The RPi and the power adapter are 1 week old.
Here is an example install.log
Thu Jan 1 00:00:07 1970 Starting OSMC installer
Thu Jan 1 00:00:14 1970 Detecting device we are running on
Thu Jan 1 00:00:14 1970 Mounting boot filesystem
Thu Jan 1 00:00:14 1970 Trying to mount to MNT_BOOT (/mnt/boot)
Thu Jan 1 00:00:14 1970 Using device->boot: /dev/mmcblk0p1 and FS: fat32
Thu Jan 1 00:00:14 1970 Preseed file found, will attempt to parse
Thu Jan 1 00:00:14 1970 Found a definition for storage: sd
Thu Jan 1 00:00:14 1970 Creating root partition
Thu Jan 1 00:00:14 1970 From a root partition of /dev/mmcblk0p2, I have deduced a base device of /dev/mmcblk0
Thu Jan 1 00:00:14 1970 Determined 255 MB as end of first partition
Thu Jan 1 00:00:14 1970 Calling mkpart for device: /dev/mmcblk0 and fs: ext4 with start 257M and end 100%
Thu Jan 1 00:00:16 1970 Calling fmtpart for partition /dev/mmcblk0p2 and fstype ext4
Thu Jan 1 00:01:13 1970 Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=2 blocks, Stripe width=1024 blocks
2035824 inodes, 8129280 blocks
406464 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=0
249 block groups
32768 blocks per group, 32768 fragments per group
8176 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624
Allocating group tables: 0/249 done
Writing inode tables: 0/249 done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: 0/249 2/249 4/249 6/249 done
Thu Jan 1 00:01:13 1970 Mounting root
Thu Jan 1 00:01:13 1970 Trying to mount to MNT_ROOT (/mnt/root)
Thu Jan 1 00:01:13 1970 Using device->root: /dev/mmcblk0p2
Thu Jan 1 00:01:13 1970 Error occured trying to mount root of /dev/mmcblk0p2
Thu Jan 1 00:01:13 1970 Halting Install. Error message was: can’t mount root
