Recently purchased the Vero 4K and have spent several hours trying to properly configure this but keep running into the same issue. Here’s a snapshot of the error message:
osmc@osmc:~$ smbclient -L 192.168.1.110
Enter osmc’s password:
OS=[Windows 10 Home 16299] Server=[Windows 10 Home 6.3]
Sharename Type Comment
ADMIN$ Disk Remote Admin
C$ Disk Default share
D$ Disk Default share
IPC$ IPC Remote IPC
Movies Disk
print$ Disk Printer Drivers
TV Shows Disk
Users Disk
Connection to 192.168.1.110 failed (Error NT_STATUS_RESOURCE_NAME_NOT_FOUND)
NetBIOS over TCP disabled – no workgroup available
And here’s what my fstab file looks like:
rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
I’m quite new to all of this so I apologize if this is a redundant question. Let me know what additional information I can provide to assist in troubleshooting.
Thanks for the quick reply. I don’t believe that I have any sort of username or password to access my Windows shares as I have “full access” set to everyone. Do you recommend I reconfigure it with a username and a password?
Strange - I attempted to use one of my existing users “Brian” and I get the same error message.
osmc@osmc:~$ smbclient -L 192.168.1.110 -U Brian
Enter Brian’s password:
Domain=[THOREAU] OS=[Windows 10 Home 16299] Server=[Windows 10 Home 6.3]
IPC$ IPC Remote IPC
Movies Disk
TV Shows Disk
Users Disk
osmc@osmc:~$ sudo nano /etc/fstab
GNU nano 2.2.6 File: /etc/fstab
Yep, those are the two sub folders within my Movies folder. Based on this, does it seem to be working properly even though the smbclient command returns an error?
Yes, as mentioned fstab mount and smbclient two different topics. Just now in Kodi add the sources via root filesystem → mnt → Server_Videos and you are done
