Hi, I’ve this error each time I try to upgrade my awsome osmc…
logs are paste with this id : waqosoqide
could you help me please ?
best,
best,
Just to save the time of the folks interested in this package issue: https://paste.osmc.tv/waqosoqide
Well it seems you have problems with more files and your package database.
If your system is not to much customised I suggest to start from scratch.
Alternatively what do you have in bunkus.org.list
? Maybe removing that running update/autoclean/dist-upgrade could fix your issue.
Sorry for the delay…
bunkus.org.list is for MKVToolnix and I use it often.
as nothing seems to fix my problems (upgrade and packages) I’ve reinstalled osmc from scratch.
so, after spending many hours to customize my media server it’s ok now.
