Error installing OSMC
Hi There,
I decided to finally try OSMC and the installer, but after installing it on my PC (Ubuntu), the install fails with the following error:
Tue Apr 7 22:38:39 2015 Mounting /dev/mmcblk0p1 to /tmp/osmc_mnt
Tue Apr 7 22:38:39 2015 Could not mount filesystem!
I tried formating the SD card with no luck , or simply wait until it fails then mount it to /tmp/osmc_mnt, but although it does mount the sd on that folder, the install fails anyway.
Can someone help me to install OSMC ?
Thanks !
no one is having this issue ?
sam, could this be a bug in our installer ?
your i meant
