Error On Installing Transmission Client
As I went ahead to install transmission client, it threw an error, telling me to post it on the forum.
The error is:
error installing: armv6I-transmission-app-osmc (2.8.4-11)
Please report it on the osmc forum
Kindly, let me know how should I go ahead. By the way I had these packages installed through ssh & shell prior to doing this through interface.
transmission-common/stable,now 2.84-0.2 all [installed,automatic]
transmission-daemon/stable,now 2.84-0.2 armhf [installed]
Many Thanks.
They will conflict.
You need to purge the old packaeges first.
OK, It installed successfully. As you said, the prior installation was interfering.
As a resolution to the problem for others also, I uninstalled it through:
sudo apt-get --purge autoremove transmission-common transmission-daemon
Many Thanks & Warm Regards.
