Error run addon my osmc?
Hi alguin can you guide me of what is the error that appears when running update of the addon my osmc
thanks
This doesn’t look like My OSMC presenting that dialogue.
Correct, it is what appears to me in the time of the traditional addon.
So as another addon interferes with OSMC I guess you would need to disable that addon.
If you need help to find out more I suggest enabling debug logging and reproducing the pop-up would be helpful
So, in summary:
  • activate the logging
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
