I have try today to upgrade from Kodi 16 to Kodi 17.
By using the OSMC updater, the update starts and after some time it is aborted with the following dialog box:
Even if the error message say “… attempting to restart Kodi in 30 seconds …” the dialog box never close and it is mandatory to “unplug / plug” my PI2 to restart OSMC.
By looking inside the /var/log/apt/term.log i can found the following:
Generating locales (this might take a while)…
fr_FR.UTF-8… done
Generation complete.
Processing triggers for libc-bin (2.19-18+deb8u7) …
Segmentation fault
Segmentation fault
dpkg: error processing package libc-bin (–configure):
subprocess installed post-installation script returned error exit status 139
Processing triggers for ca-certificates (20141019+deb8u2) …
Updating certificates in /etc/ssl/certs… Segmentation fault
Segmentation fault
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…done.
libc-bin
I have also try to manually upgrade Kodi by using
sudo apt-get update
sudo apt-get dis-upgrade
==> same error
After this last try (manual update), i have use the command
grab-logs -A
and the logs have been uploaded to
http://paste.osmc.io/ugamofuzay
Please, could you help or give some advises.
