So I bought the Vero… all exited and joyful…
But there is a few quirks I haven’t been able to figure out how to solve.
When I try to use airplay from my Ipad, I just get a lot of static in the top of the screen, followed by a completly green screen…? any sugenstions?
I would really like to download torrents directly on the Vero (as it is always on, and dosen’t make a lot of noise). Is it possible? and then how/what add-on to use?
My Vero is connected to a projector (Optima). Every time I want to use the vero, I need to pull out the powercord and restart the Vero. Otherwise the projector won’t find and registre the vero as hdmi-source?
I need a good Ipad or Android remote, as I would like to be able to control the vero for music use, without needing to turn on the projector. Right now I use the “Kodi remote” for ios, but it dosent really work that well with the vero. Any sugestions?
Well… …Now I had some time try try out different solutions.
The question about airplay: I have got it to show pictures and play sound, as soon as I try with video, it freezes. I’ve tried youTube, that just gives me an error, and HBO, that supposedly should have full airplay and chromecast, still just shows me a lot of green colors and static. Well I’ll live without!
The question about torrent: I’ve tried to download the new Transmission Torrent Client… …it tells me that the update and instillation was successful, but afterwards it shows up as not installed. Besides I would really like a small introduction to the use of “port 9091” in a webbrowser.
The question about hotplugging: As I can tell, we are now at RC3 0.9.9 , So I hope my trouble will be over when we hit 1.0
The question about remotes: I gave up, as far to often, I do not get the desired results. As long as pop-up messages dosen’t relay back to the remote, I am stuck everytime something unexpected happens.
