I am on an raspberry pi 3 B
and i am getting this error when loading
switch_root: can’t execute “sbin/splash_early” : Exec format error
This sounds strange. I assume this prevents your Pi from booting, or?
Do you have a direct OSMC installation or is it NOOBS based?
Was this version running before?
It prevents from it booting and I installed OSMC using windows and I formatted the MicroSD card using this guide
http://paste.osmc.tv/ogaquxuquv.vhdl
And i just installed it.
first time.
- So the installation went through without a problem and this error is shown when you reboot first time?
- Did you used the OSMC Installer and the latest Image to install?
- Suggest to test the SD Card with H2Testw
- Yeah.
- Yeah.
Do I need to format the card before using h2testw?
I can assure that everything is ok with the card. I have used it for an raspbian setup.
No, no need to format before using h2testw.
Generally you should also have no need to create a partition
We suspect an issue with your SD card. For that we suggest the following procedure on a Windows OS to verify the card’s correctness:
Download the official SD Memory Card Formatter from the SD Association you can find at
Downloads URL - SD Association -
Re-format the card using this tool. It will be visible in Windows as drive letter.
Download the h2testw tool you can find
at Ihre Suche | heise Download
(Unfortunately the web page is in German but strictly follow the download buttons, english info about the tool can be found here H2testw English Windows | Fake Flash Memory Information - FlashChipDirector) -
Run h2testw and test the SD card.
We hope your card is still fine but keep in mind SD cards have a limited lifespan. In case of errors with h2testw we recommend you to change the SD card. If you would like to get a good quality SD card manufactured for OSMC, then you can find one in the Store.
