OSMC uses the ntfs-3g FUSE driver which has the same partition size limits as Windows currently does. As that limit is 8 petabytes with a 2MB cluster size I don’t think it should be much of a concern. As for how well NTFS works on OSMC it is not an issue as far as compatibility, but it does transfer slower than other options. This would be of no concern if you are just having the Vero read media from it as it is plenty fast for that, but if you are transferring files to it over a network then it is going to only go around 30MB/s whereas ext4 can do around 100MB/s. If you want to keep it fully native Windows plug and play R/W then exFAT is the better choice as it is faster in Linux than NTFS due to having a native kernel level driver.
My concern was, if the Vero V’s operating system could handle such big HDD sizes. I come from a Android system (Fire Cube) where it seems that 16 TB HDD size is a limit because of the 16 bit nature of the Android system on the Fire Tv or maybe the driver of the Fire OS.
As I mean to understand, I don’t need to worry about those limitations on the Vero V with OSMC and Kodi.
I saturate my gigabit network sending files to a USB 3.0 connected NTFS drive without any issue and easily get >110 MBs. You should only see ~30 MBs if you are plugged into the USB2.0 port.
Thanks for that correction. I had a hunch that it could go faster but I didn’t have the time at the moment to retest and the stupid AI that I had crawl my historic posts swore that was the speed that I had personally posted a couple years ago for the V. I don’t suppose you know currently what kind of performance you get with exFAT do you?
I don’t recommend playing from NTFS by USB on the Vero-V. It’s faster to use exFAT. The NTFS driver is a user space driver which carrries overhead. The 4.9 kernel has a native exFAT driver that reads faster. I did reading tests from USB with a dry dd command and i got 200 MB/s or so. With a 64kb cluster NTFS on another older pendrive I got slow transfers like 20 MB/s and crashed once playback of 60 Mbps files. I have to say the NTFS pendrive was the same slow on a Windows machine. But once formatted to exFAT and 128 kb cluster size it flew on both Windows and the Vero.
If your drive is already NTFS I wouldn’t bother migrating your stuff off so you can reformat it to another file system. If you have a blank drive and your intent is to have it plugged into the Vero V exclusively, well then you should probably be using ext4. If the drive will be getting unplugged and moved to other machines (Windows, MAC, etc) then NTFS and exFAT have their merits.
I’m not some defender of NTFS, most of my drives are ext4, but my NTFS drives perform right on par with the ext4 ones so I’m not going to change them. When I was getting and adding new drives I did many tests with various file systems, cluster sizes, inode counts, you name it. The differences are all really trivial for the use case.
