Just received my new 4K+.
Is there a way to backup my previous older Vero configuration (network settings, shares and audio settings) and import it on the new 4K+ ?
Thank you
Yep – you can do this via My OSMC -> Backup
If you are familiar with the command line, you can also just copy the entire ~/.kodi directory – provided that both devices are on the same version.
Very familiar with command lines Thanks Sam.
