February update issue on my raspberry pi b+
I’ve had some issues with the last OSMC update on my raspberry pi 2 b+. After february update, the system is stuck on the skin splashscreen and the media center does not get launched.
Does anyone have the same issue? How to solve?
Can you log in via ssh and provide logs?
If it’s been a while since you updated, Kodi may be updating its database and that can take quite a bit of time, and look like it’s hung. It’s the change from Kodi 15 to Kodi 16.
So if that’s the case, just be patient. If you are already on Kodi 16, then do as mcobit asked and try to ssh in a post the logs.
It’s stuck since more than one day, so I don’t think it’s the database update. Which logs can I provide?
From command line grab-logs -A
Details regarding how to access the command line interface can be found here on our Wiki: Accessing the command line - General - OSMC
Here’s the log
There have been reports of a bug in Kodi’s implementation of UPnP in v16. It appears to hang/crash shortly after the UPnP server and client start. You could try renaming/deleting ~/.kodi/userdata/guisettings.xml in order to revert them being enabled and reboot the box. If that is indeed the issue, it should bring a Kodi up without issue.
