Is there any media player i can install on my Vero 4k+ to play any video format ?
Basically i want to watch all my movies with vero 4k+ and not stream them.
I have a philipps Tv which i connect to vero 4k+ with HDMI cable and then plugin my wd media external 3 terabyte harddrive with my movies to vero 4k+. Is there any program that i can play any video format on my vero 4k+ ?
And what i also saw is that i can’t see the full subtitles of a video if i play it:
The letters are almost invisible and way below. How i can adjust subtitles more up in the movie or series ?
And is there any other remote controll zapper which i can use which has normal batteries ?
We’ve provided a simple tutorial on how to provide logs so that we can determine your issue.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Thanks, i could figure out what not worked with the video. I didn’t saw
that i clicked the folder in the folder and not the video itself. My blooper.
Aspect setting is set to 1:1.
I not changed anything but i tried the different modes, strech mode ect, not changes anything with the subtitles. They still just shown way below.
And what do you mean with “just scan” ?
I still can’t figure out how to adjust them more up.
They still seem way to below. I also tried zoom function, wide stretch ect. not helps.
My Display Mode is set to full screen, Resolution: 1920x1080i. Refresh rate: 60.
If i play any video it always goes view mode “custom” which seems normal besides the subtitles way below.
Another Question is how can i set in setting that it always plays any video with the subtitle which is in it ?
I tried on few videos to set it as “default” but as soon i clicked in another video i manually had to click
show subtitle again.
They are going to be wrong until you get the GUI displaying properly.
Since you’ve been changing lots of setting, I’d suggest starting fresh, so first thing is to make sure that your TV is set to 1:1 for the display option. Once that’s done, ssh into your Vero and run these commands:
Where do i find this “Display option” ? And how do i enter these commands in ssh on vero ? I went into the ssh on vero but i don’t see how i can enter any commands.
What is that $ prompt ? I went into My OSCM/Services/ and it shows SSH Server running and an empty field. How can i enter the commands in this empty field ? If i click on it it says “Pending Actions Disable: -SSH Server” but i see nothing else to click how i can enter something. Or how do i connnect with this ssh ?
Thanks. I fixxed everything. Went to my normal tv setting and played around till i found how to setup it.
Thanks i fixxed it.
Thanks everyone for his help ! It now works.
For the remote controll i also found a solution and saw in vero that they support my WD media player remote controll so i activated that function and it works perfect. Thanks everyone.
