Hey everyone, I’m new to OSMC, love it for the most part except that I can’t seem to get any of my files stored on the SD card on my pi to load into the Library. I feel like I’m generally pretty capable of figuring these things out but this one has me stumped. I’ve just spent +5 hours trying to get it working with no luck.
Tried multiple file locations, setup a new OSMC profile, different file formats (.mp3, .mp4, .m4a) and nothing seems to work. I can play the files if I select them manually but they are unavailable in the library/party mode, etc.
I’ve searched all the forums I could find and don’t have a solution, I’m hoping you guys can help me figure it out.
Below are the logs from the moment I click “Ok” when adding a new source to music and saying yes to updating library.
osmc@pi:~/.kodi/userdata$ kodi --version
17.1 Media Center Kodi
Copyright (C) 2005-2013 Team Kodi - http://kodi.tv
18:56:55.182 T:1958257584 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:56:55.282 T:1958257584 DEBUG: OnKey: return (0xf00d) pressed, action is Select
18:56:55.284 T:1958257584 DEBUG: ------ Window Init (DialogConfirm.xml) ------
18:56:55.561 T:1958257584 DEBUG: ------ Window Deinit (DialogMediaSource.xml) ------
18:56:55.697 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:00.982 T:1958257584 DEBUG: Previous line repeats 3 times.
18:57:00.982 T:1958257584 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
18:57:00.983 T:1958257584 DEBUG: OnKey: left (0xf082) pressed, action is Left
18:57:01.099 T:1958257584 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
18:57:01.513 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:01.549 T:1958257584 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:57:01.629 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:01.632 T:1958257584 DEBUG: OnKey: return (0xf00d) pressed, action is Select
18:57:01.633 T:1958257584 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:57:01.878 T:1958257584 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
18:57:01.882 T:1633678320 DEBUG: Thread MusicInfoScanner start, auto delete: false
18:57:01.882 T:1958257584 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:57:01.883 T:1958249456 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
18:57:01.884 T:1958249456 DEBUG: GOT ANNOUNCEMENT, type: 32, from xbmc, message OnScanStarted
18:57:01.918 T:1958257584 DEBUG: CGUIMediaWindow::GetDirectory (sources://music/)
18:57:01.919 T:1958257584 DEBUG: ParentPath = [sources://music/]
18:57:01.928 T:1958257584 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
18:57:01.930 T:1958257584 DEBUG: RetrieveMusicInfo() took 0 msec
18:57:01.946 T:1667232752 DEBUG: Thread BackgroundLoader start, auto delete: false
18:57:01.948 T:1958257584 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:57:01.963 T:1667232752 DEBUG: Thread BackgroundLoader 1667232752 terminating
18:57:01.965 T:1958257584 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
18:57:01.966 T:1633678320 DEBUG: Process - Starting scan
18:57:01.966 T:1667232752 DEBUG: Thread MusicFileCounter start, auto delete: false
18:57:01.971 T:1667232752 DEBUG: Thread MusicFileCounter 1667232752 terminating
18:57:01.973 T:1633678320 DEBUG: DoScan Scanning dir '/home/osmc/Movies/' as not in the database
18:57:02.049 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:02.418 T:1616901104 DEBUG: Previous line repeats 5 times.
18:57:03.710 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/sources.xml'>
18:57:03.717 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:03.721 T:1616901104 DEBUG: [service.watchdog] [event] <created> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:03.721 T:1616901104 DEBUG: [service.watchdog] [event] skipping <created> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:03.722 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database'>
18:57:03.722 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:03.723 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:04.241 T:1616901104 DEBUG: Previous line repeats 1 times.
18:57:04.241 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db'>
18:57:04.241 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:06.079 T:1616901104 DEBUG: Previous line repeats 1 times.
18:57:06.079 T:1616901104 DEBUG: [service.watchdog] [event] <deleted> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:06.080 T:1616901104 DEBUG: [service.watchdog] [event] skipping <deleted> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:06.081 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database'>
18:57:06.082 T:1616901104 DEBUG: [service.watchdog] [event] <created> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:06.084 T:1616901104 DEBUG: [service.watchdog] [event] skipping <created> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:06.086 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database'>
18:57:06.087 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:06.456 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db'>
18:57:06.623 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
18:57:07.746 T:1633678320 DEBUG: Previous line repeats 2 times.
18:57:07.746 T:1633678320 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:05
18:57:07.747 T:1633678320 DEBUG: Process - Finished scan
18:57:07.748 T:1958249456 DEBUG: CAnnouncementManager - Announcement: OnScanFinished from xbmc
18:57:07.748 T:1958249456 DEBUG: GOT ANNOUNCEMENT, type: 32, from xbmc, message OnScanFinished
18:57:07.753 T:1633678320 DEBUG: Thread MusicInfoScanner 1633678320 terminating
18:57:07.766 T:1958257584 DEBUG: CGUIMediaWindow::GetDirectory (sources://music/)
18:57:07.766 T:1958257584 DEBUG: ParentPath = [sources://music/]
18:57:07.776 T:1958257584 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
18:57:07.777 T:1958257584 DEBUG: RetrieveMusicInfo() took 0 msec
18:57:07.793 T:1633678320 DEBUG: Thread BackgroundLoader start, auto delete: false
18:57:07.812 T:1633678320 DEBUG: Thread BackgroundLoader 1633678320 terminating
18:57:07.970 T:1958257584 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
18:57:08.273 T:1616901104 DEBUG: [service.watchdog] [event] <deleted> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:08.274 T:1616901104 DEBUG: [service.watchdog] [event] skipping <deleted> <u'/home/osmc/.kodi/userdata/Database/MyMusic60.db-journal'>
18:57:08.274 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/userdata/Database'>
18:57:08.274 T:1616901104 DEBUG: [service.watchdog] [event] <modified> <u'/home/osmc/.kodi/temp/kodi.log'>
