G’day there, I Need Help DeBugging the Log that I Posted Earlier 2day @ https://paste.osmc.tv/orovifafin
This has been a Fresh install on a 16 GB Micro SD Card in a Raspberry Pi 2
the Wireless was previously working, But sum thing somehow got Corrupted… Somehow Me FLAC Music Files ( some but Not all ) got Copied from Me USB Flash Drives onto the Micro SD Card ( I have 7 USB Flash Drives Connected via a 10 Port USB Hub, Because it Did Used 2 Work! ), Altho I’ve got a Virtually New 1 TB eXternal USB3 Pocket Dr w/ much the same Files on a NTFS File System that I could Never get OSMC Kodi 2 see ( No Matter How Much interNet Research I did, Altho it’d Certainly be my Preference! )
Please Help!
:-\K
I moved your post to a new topic as it had nothing to do with the topic you replied to.
Looking at your logs, it looks like your drives are all being mounted in /media where they should be.
It looks like it might be an iffy SD card:
Jun 28 15:22:01 osmc kernel: mmc0: cmd op 24 arg 0xdf42 flags 0xb5 - resp 00000900 00000000 00000000 00000000, err 0
Jun 28 15:22:01 osmc kernel: mmc0: data blocks 1 blksz 200 - err 0
Jun 28 15:22:01 osmc kernel: mmc0: =========== REGISTER DUMP ===========
Jun 28 15:22:01 osmc kernel: mmc0: SDCMD 0x00004098
Jun 28 15:22:01 osmc kernel: mmc0: SDARG 0x0000df42
Jun 28 15:22:01 osmc kernel: mmc0: SDTOUT 0x017d7840
Jun 28 15:22:01 osmc kernel: mmc0: SDCDIV 0x00000003
Jun 28 15:22:01 osmc kernel: mmc0: SDRSP0 0x00000900
Jun 28 15:22:01 osmc kernel: mmc0: SDRSP1 0x0000182e
Jun 28 15:22:01 osmc kernel: mmc0: SDRSP2 0xffffffff
Jun 28 15:22:01 osmc kernel: mmc0: SDRSP3 0x0002400f
Jun 28 15:22:01 osmc kernel: mmc0: SDHSTS 0x00000081
Jun 28 15:22:01 osmc kernel: mmc0: SDVDD 0x00000001
Jun 28 15:22:01 osmc kernel: mmc0: SDEDM 0x00010801
Jun 28 15:22:01 osmc kernel: mmc0: SDHCFG 0x0000050e
Jun 28 15:22:01 osmc kernel: mmc0: SDHBCT 0x00000200
Jun 28 15:22:01 osmc kernel: mmc0: SDHBLC 0x00000001
Jun 28 15:22:01 osmc kernel: mmc0: ===========================================
Jun 28 15:22:01 osmc kernel: mmcblk0: error -110 transferring data, sector 57154, nr 1, cmd response 0x900, card status 0x0
If possible, reinstall OSMC on a new SD card.
G’day again Guys, I’ve done another Fresh install on a 32 GB Micro SD Card & I saw the same message while Trying 2 Connect the Wireless Networking Add-on Unhandled exception caught - See log for details. Which I’ve Posted here https://paste.osmc.tv/uteminozod
Please Help!
Can you please enable debug logging (Settings-System-Logging-Debug logging) re-start OSMC and post logs again.
Thanx 4 your Support All… As Requested… https://paste.osmc.tv/ofudoxehiz
Bless Ya
;-)K
