I’m using a RPi 3. I used the latest image which is OSMC_TGT_rbp2_20171001.img.gz. This is my first time using OSMC ever.
I used the installer and got the image onto the card. The pi launches and it goes to the first OSMC screen, then jumps to language. I am presented with the list of languages, presumably to finalize the install. Thing is I can’t select anything. I can’t scroll through the names, nothing.
I tried two different logitech keyboards, fresh batteries.
I was reading the forum, some people are talking about connecting ethernet in order to do this step, but I can’t really do that in my house setup, I don’t have a cable and the router and TV is way separate. I don’t see how I’d pull that off.
When I did the installer from my main computer originally I did enter my SSID and wireless password expecting that it would connect to the network on boot.
please help. Hard to imagine it’s a hardware thing because the keyboards work elsewhere. I think the USB ports are working fine because when I had a flash drive connected, it was blinking, getting powered and seemed to be mounting. I wish I had other info I could provide, I can’t SSH it doesn’t show wireless as a connected source on my network map.
thanks!
