Hi guys, new here and I’m rather stuck.
When starting up the Raspberry Pi for the first time the screen is red (top left), yellow (top right), blue (bottom left) and cyan (bottom right).
Tried formatting the sd card and starting again but no luck.
I’m following a tutorial online which says I should extract the downloaded zip file directly onto the SD card. The image comes directly from the raspberry pi website.
Ah ok, you are using the NOOBS install by the sounds of it. What do you have on the SD card, can you give me dome file or folder names or show me a screenshot of the contents.
Our preferred method of install is to use the OSMC installer from here;
I’m having the same issue. Pi 2. I’ve done this dozens of times, but am stuck on rainbow screen. Will try another SD and report back.
Update: After 3rd image download, I tried ‘stuck’ SD card in Pi 3, and it is now installing. Will try to move back to Pi 2 after install.
Update 2: No luck transferring from pi 3 to pi 2. Just a black screen. I’ve tried all 3 build versions that are available for the Pi 2 on the installer, and all 3 get stuck on the rainbow screen. Need a fix for this.
While I can respect that you think that, I’ve dealt with these things for quite some time. I most definitely am working with Pi 2. (4 usb ports, no chip on bottom).
