I Have a raspberry pi 2 with OSMC. I Have Transmission, a 1TB Driver via USB NTFS and Samba running with the OSMC. It’s work fine with videos less ~2GB and low quality, but HD and Full HD, its freeze after 10~30 minutes, and i need stop the movie and start again… Anny idea? My log:
Need to narrow it down as there are a number of possible culprits.
Start by disabling the overclock.
If that doesn’t help then try disabling transmission.
If that doesn’t work remove the 1TB drive (and play files from sdcard or from a network source).
i try this thigns and not work…
It would be good if we could find out more about the file you are having issues playing. Please see the mediainfo section in How to submit a useful support request - General - OSMC
This is the info returned: http://paste.osmc.io/ubutubahah.tex
Anny idea?
