I’m experiencing frequent audio dropouts on a Rpi 3b+ running OSMC, kodi 18.3, compiled 2019-06-19.
The RPI is via HDMI connected to an Onkyo AVR.
I have a 2.0 audio system with front speakers only. And the problem is happening more often with files encoded in 5.1 surround. I’ve tried running with and without audio passthrough with no big difference.
Is there a usual culprit that’s causing this issue?
I’m no expert but service.upnext seems to be doing a lot and presumably taking up CPU cycles while the video is playing. Can you try disabling that add-on?
