Hello,
I am getting audio drops with my vero 4k, this is happening with both video and games. This is happening with a clean install of osmc of the latest version (although the attached logs have been taken after xboxdrv was installed)
Watching a video series it seems to occur more frequently during quiet parts or much less frequently when a scene changes. When playing a game, I have to adjust the ingame volume firstly using select+right joystick on a wired 360 controller. Then when adjusting the volume lower, the audio either drops completely (might just have hit the volume threshold) or when a sound repeats for an extended period of time all audio will drop until the sound stops.
I thought the issue initally was the cheap projector I purchased as I used the projectors inbuilt audio and then the projectors audio out with a portable speaker. I then used the vero 4ks audio out but my headphones/speakers aren’t active so the audio has to be almost maxed out to hear. I purchased an external amplifier/DAC to overcome this and have the vero using that in audio settings. Nothing changed.
I have enabled ‘Send low volume noise’ and ‘Keep audio device alive’ as ‘1 Minute’. I have also noticed that the GUI sounds no longer seem to play, although Im not sure if this was removed in a previous release (My vero has been in storage for a few years)
I am still to test with a monitor and headphones, I will try and provide an update soon.
Summary
General
UniqueID/String : 185460556975701112845744773172605623011 (0x8B86676DBD0222E1C4B6DCC6877A1AE3)
CompleteName : C:\Users\theda\Documents\Westworld.S02E05.Akane.No.Mai.720p.10bit.WEBRip.2CH.x265.HEVC-PSA.mkv
Format/String : Matroska
Format_Version : Version 4
FileSize/String : 321 MiB
Duration/String : 1 h 1 min
OverallBitRate/String : 736 kb/s
Movie : PSArips.com | Westworld.S02E05.Akane.No.Mai.720p.10bit.WEBRip.2CH.x265.HEVC-PSA
Encoded_Date : UTC 2018-05-21 05:03:31
Encoded_Application/String : mkvmerge v23.0.0 (‘The Bride Said No’) 64-bit
Encoded_Library/String : libebml v1.3.6 + libmatroska v1.4.9
Video
ID/String : 1
Format/String : HEVC
Format_Profile : Main 10@L3.1@Main
CodecID : V_MPEGH/ISO/HEVC
BitRate/String : 654 kb/s
Width/String : 1 280 pixels
Height/String : 720 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 (24000/1001) FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 10 bits
Bits-(Pixel*Frame) : 0.030
StreamSize/String : 286 MiB (89%)
Default/String : Yes
Forced/String : No
Audio
ID/String : 2
Format/String : AAC LC SBR
Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
Format_Commercial_IfAny : HE-AAC
Format_Settings : Explicit
CodecID : A_AAC-2
BitRate/String : 80.2 kb/s
Channel(s)/String : 2 channels
ChannelLayout : L R
SamplingRate/String : 48.0 kHz
FrameRate/String : 23.438 FPS (2048 SPF)
Compression_Mode/String : Lossy
Video_Delay/String : 23 ms
StreamSize/String : 35.0 MiB (11%)
Language/String : English
Forced/String : No
Text
ID/String : 3
Format/String : UTF-8
CodecID : S_TEXT/UTF8
CodecID/Info : UTF-8 Plain Text
Duration/String : 1 h 0 min
BitRate/String : 31 b/s
ElementCount : 486
StreamSize/String : 13.8 KiB (0%)
Forced/String : No
mkv
https://paste.osmc.tv/yibapokava
snes game
https://paste.osmc.tv/ipaharefon
