Device: Rasp Pi 2,
Installation media: SDcard, USB Hard Drive
Connection: Wired
Power Supply Type:
Power specs: 5V 200mmA
Storage: Seagate 5T USB hard-drive
Peripherals: USB Hard Disk, Bluetooth Logitech Keyboard K400r with bluetooth dongle
OSMC version: VERSION_ID=“2015.08-1”
Hi All,
I am currently experiencing frequent kernel freezing, I am concerned because the O.S. is running from an external HD which works also as “NAS” and when the PI2 is freezing nothing works and I obligated to remove the power supply. Unfortunately seems the combination “alt+stamp+REISUB” deoesn’t work from the bluetooth dongle of the keyboard. I started to experience this freezing when I installed from the “app store” Transmission.
The logs I posted below are from the last freeze, in particular during the last block the mediacenter was been stopped to avoid problems with Transmission but the system has been blocked the same.
I am not pretty sure but probably it happened also a couple of time without Transmission working, usually happens after some hours of inactivity (3 or more).
I will stop to use Transmission for a while and reporting any issues.
Hi, after a couple of days without problems today when I came to home I had another freezing.
I left the PI2 on this morning without transmission so my mother in law could put some Italian cartoons to my son instead the English toons by Comcast, when I went to shutdown the PI2 I found glitch on the graphics and the cursor frozen.
Has been impossible uploading by OSMC the log because it weight 157 MB, so something is not working properly. I uploaded the log by gdrive:
There is an update that fixes the oversized log issue and performance so first you need to update. After if the problem still occurs try turning off screensaver and upload a log.
Reading package lists... Done
Building dependency tree
Calculating upgrade... The following packages were automatically installed and are no longer required:
libflac8 rbp2-image-4.1.3-2-osmc rbp2-image-4.1.5-1-osmc
Use 'apt-get autoremove' to remove them.
Done
Any way this alert was been pretty weird.
Just another quick question, do you think is the screen saver the cause of those blocks?
another block, all the time the screen blinking with this emoticon :(, impossible login on the consoles, every time I tried to put the username the screen blinked to this the emoticon screen. Pretty annoying.
Hi thanks for your help and replies, I should check because I enabled the soft overclock but I don’t remember if I enabled the “turbo” mode as well. As I far I know I always read to do not enable this feature.
Any way I will remove any overclock and I’ll let you know, thanks!
Hi guys, I enabled Transmission to test the system and until now (a couple of days) I have never had any freezing even watching a movie, using Transmission and copying a heavy files from my computer the OSMC usb hard drive, I will take another couples of day to close this thread, thanks to all!
