Does OSMC support wma files? Scanning or opening a folder with wma files causes a crash.
Generally WMA files are supported, but not the Pro version and some other specific versions. To check what goes wrong I suggest to enable debug logs and share them.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Are you using a NFO file?
OK, thanks. I’ll get the logs uploaded.
My other media center with an RPI4 running Kodi has no problems scanning the very same WMA files. And my Vero 4K - OSMC media center did once do a successful scan of all the WMA files.
My logs are at: https://paste.osmc.tv/uparijelow
I also went into the WMA files being scanned during the crash and cleaned up many of the unusual or duplicated tags. They still cause OSMC to frowny face.
I am considering performing a fresh OSMC install on my Vero 4K to get past this problem.
I don’t see any attempt to scan files in the logs you posted. Please reboot twice, run the scan and then post new logs.
We’ve provided a very specific, and not terribly complicated way to provide logs. Use paste.osmc.io
