I had in the past a Raspberry PI, and I remember writing a fstab file.
Then I changed for the Vero, and although I didn’t write this file, I still have access to my NAS . I added the sources in the options.
But I wonder if the fstab file is necessary ? I have some big files (bitrate > 50 Mbs/s from Media Info). First the file is very choppy at the beginning, then play some time than freeze, then play…
I use a ethernet cable cat6 between the nas, the pc, and vero.
The file is UHD 4K.
I created a fstab file, now all the files that had problems play now without problem.
Some of them have a bitrate near 75 Mb/s.
The only problem I had is that the automount don’t work by default; after digging in the forums, I found a solution. This is my fstab, for information :
