FTP No access and Folders not showing photos
After the august update FTP doesn’t work anymore …can’t access vero from it …did vero default username change? I tried both default pw and current one and didn’t work …samba works but hate using it
The default credentials are still both ‘osmc’.
No changes to FTP server in this update.
remove FTP and tried reinstalling it, doesn’t install …error …told me to tell you ;-(
plus I use to see photos on the left side panel on my video’s folder after update it’s gone, it’s just blank folder now, I Have to click folder to see the photo but that don’t help if I want to scroll over 1000 movies
Please post some logs.
Is this it?
https://paste.osmc.tv/exilorucis
Actually you seem to already have had issues before the August update with trying to remove/add FTP and/or SSH.
Log started: 2021-05-25 08:53:21
Selecting previously unselected package vsftpd.
Preparing to unpack …/vsftpd_3.0.3-12_armhf.deb …
Unpacking vsftpd (3.0.3-12) …
Selecting previously unselected package ftp-app-osmc.
Preparing to unpack …/ftp-app-osmc_1.1.5_all.deb …
Adding ‘diversion of /etc/vsftpd.conf to /etc/vsftpd.conf.distributed by ftp-app-osmc’
Unpacking ftp-app-osmc (1.1.5) …
Setting up vsftpd (3.0.3-12) …
Created symlink /etc/systemd/system/multi-user.target.wants/vsftpd.service → /lib/systemd/system/vsftpd.service.
[vsftpd.conf:1] Line references path below legacy directory /var/run/, updating /var/run/vsftpd/empty → /run/vsftpd/empty; please update the tmpfiles.d/ drop-in file accordingly.
Setting up ftp-app-osmc (1.1.5) …
Processing triggers for systemd (241-7~deb10u5) …
Log ended: 2021-05-25 08:53:27
Log started: 2021-05-27 21:11:35
Removing ftp-app-osmc (1.1.5) …
Removing ssh-app-osmc (1.2.4) …
Removing ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.distributed by ssh-app-osmc’
dpkg-divert: error: rename involves overwriting ‘/etc/ssh/sshd_config’ with
different file ‘/etc/ssh/sshd_config.distributed’, not allowed
dpkg: error processing package ssh-app-osmc (–remove):
installed ssh-app-osmc package post-removal script subprocess returned error exit status 2
ssh-app-osmc
Log ended: 2021-05-27 21:11:36
Can you currently login via SSH? If not then suggest to connect a keyboard to go to the console locally to try to get SSH reinstalled.
Yes that was weird, I did have a problem, then a week later I was able to install it and I was able to use FTP (maybe after one of the minor update) …I’ll be away from my vero a week so I’ll try when I get back
ok, I believe problem solved! not sure what really happened, but I came back and installed it perfectly, then winSCP started acting up, root password for some reason got screwed up (I never touched it), I used your “OSMC_Passwd_Restore-main” and I resetted password …thanks
