For a couple of weeks I have some problems with fullscreen when watching movies. Every time when I pause the movie the litle dialog in the corner remains after playing again. A similar problem appears when trying to use the menu while fullscreen. It is only possible to reach the menu if I pause. Another problem is the “working” dialog. When starting a movie that dialog remains slightly visible occasionally.
I use the Confluence skin. But the same problems appear with a different skin.
Thanks in advance.
We need a complete set of debug enabled logs to see what’s going on here.
I have just found the setting which was responsible for the strange behaviour. It´s the checked “Adjust display refresh rate”. Unchecking it solved the problem.
If disabling that fixed the problem, that is a bug that needs to be fixed. Can you take a photo of the problem when it occurs ?
I think taking a photo wont help. Every dialog stays on fullscreen and won´t disapear. When trying to activate the menu (e.g. when pressing the middle button on Yatse) the menu won
t appear until the movie is paused.
Sometimes even the volume control bar stays visible.
Btw I use “DVDplayer” due to the hifiberry soundcard.
