first of all, I searched the forum for similar topics. But i could not find any definite statements. Can anyone confirm, that you can get a TP-Link T2UH (lsubs shows 148f:761a) working in one of the newer OSMC-Images (actually mine is 4.3.3-3)? If yes, what is needed to do? I tried a lot of different things but nothing worked out for me. Tried it with integrated mt7601u driver but it seems to need a mt7610u. Any help of how to get it work or a definite statement that it is not possible would help me a lot. Thanks!
I’ve just bought the TP-Link T2UH. I was not thinking much, I’ve seen Linux driver on their website I thought it would work… Should I return it or is it now working ?
If I open it , I cannot return it. I’ve just been plain stupid in not checking before buying. I found that there is a modified driver on github but I don’t really know what it means nor how to use it… ?
Based on that do you people think I should just return it or will it probably work? Seems stupid I know but I would be mad if I opend the box test it and cannot get it to work. 30euros lost just like that…
It might work, but we can’t guarantee it. If there’s a VID/PID miss then I can add support, but it wouldn’t be available until OSMC’s February update at the earliest now.
I want to support as much hardware as possible but won’t recommend something unless it’s guaranteed to work.
30 euros seems a little high for an MT7610U device.
They would not give me my money back so I just decided to try!
It worked out of the box but I could not connect. After some research I found that I had to disable the integrated wifi of pi 3 with dtoverlay=sdhost .
Still, it only shows 5.0Ghz Wifi while the dongle should show both 2.4 and 5.0. Not that this is much of a problem but would another driver help? (I am using a TP-Link T2UH as stated before)
I just don’t have the least idea how to try it. Or if it is even not already included… I am a 1 month noob in linux world… Trying my best to learn , nevermind I’ll figure it out.
Has anything related changed in last update? The dongle has been working flawlessly for month now and suddenly it simply doesn’t work anymore. No wireless found…
That’s weird… Suddenly I have no wireless internet. I’ve had to comment out dtoverlay=sdhost to get the original wifi back to see if something was wrong. I really have no idea why it won’t work. I had not installed anything myself since it happened to work out of the box… I’ve tried rebooting and lsusb shows the device
