My SD card has damaged and I had to reinstall everything to a new SD card.
I did a fresh install, then copied the entire content of my old .kodi folder to the new install.
Everything works, except the IR remote control.
I use a GPIO receiver and as far as I remember I’ve used one of the default conf files the last time, selected from the OSMC Receiver menu.
How can I test if the IR receiver is getting any data or not?
I’ve tried:
sudo systemctl status lircd_helper@lirc0
* lircd_helper@lirc0.service - lircd remote support
Loaded: loaded (/lib/systemd/system/lircd_helper@.service; static)
Active: inactive (dead)
Where “dead” is not too promising.
Running the latest OSMC on a Raspberry Pi 3.
Thanks in advance,
Gabor
