Generally the Vero4K is working well.
I have an issue where the GUI performance is slowly degrading over time.
After 2-3 days it can become noticeably choppy, and after a week or so annoying to use. When it’s really bad even videos can have the occasional stutter.
A quick reboot has it back to it’s snappy self.
Although it’s not a big deal to reboot every once in a while, perhaps there is another kind of solution?
Uploading a log is quite tough. It can take 1-2 days to become jerky, and turning on the logs makes the system unusable because of the log output to the upper left corner.
noticed the same thing but with a more demanding skin (Xperience1080). Didn’t report this yet as i thought it would be skin related and did not bother me that much.
Btw, restarting the whole system is not necessary, it is enough to restart kodi (atleast for me).
(SSH: sudo systemctrl restart mediacenter)
Thought about just adding a cronjob at 5am to do this every day.
Problem is not GUI is too sluggish to grab the logs. Problem is enabling logging turns on system info output constantly on the screen. Hard to use the system this way for a couple of days.
You can enable debug logging without the screenoverlay as fzinken posted above:
@TheHacker66:
Sure its a workaround but since nobody else yet reported anything like that i thought it would be skinrelated. Will do some some testing now and see if i can find out more if i have the time.
