Hi guys - i’ve just started playing with OSMC on a RPie V1 (will be upgrading soon). I have the latest release source.
If I hit ‘S’ on the keyboard, it popups a menu:
Exit
Power off System
Custom shutdown timer
Reboot
If I hit ‘Exit’ it either hangs or gives me the BSOD sad face.
Shane
How long are you waiting to determine that it has hung ?
How many addons have you installed ? The usual cause of a hang when trying to exit is a misbehaving or poorly coded addon.
I left it sit for well over 5 mins - was completely non responsive. The odd thing was didn’t shutdown - I hit Exit.
Anyway I get it is probably an add-on issue - I have a few running.
