I have seen many posts about VERO4K+ Network Speeds… Below is the output from my Vero4K+. If you are experiencing any slow network rest assured that it’s not your Vero 4K+ and it can be a cheap switch, Router, faulty network cable.
With a cheap CAT-6 network Cable:
osmc@MBRVero4Kplus:~$ ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x0000003d (61)
drv link timer ifdown ifup
Link detected: yes
After I replace my network cable with shield CAT-6:
osmc@MBRVero4Kplus:~$ iperf3 -c 192.168.1.117
Connecting to host 192.168.1.117, port 5201
[ 4] local 192.168.1.140 port 43915 connected to 192.168.1.117 port 5201
[ 4] 0.00-1.00 sec 114 MBytes 959 Mbits/sec 0 2.83 MBytes
[ 4] 1.00-2.00 sec 111 MBytes 932 Mbits/sec 0 3.04 MBytes
[ 4] 2.00-3.01 sec 112 MBytes 939 Mbits/sec 0 3.04 MBytes
[ 4] 3.01-4.00 sec 111 MBytes 936 Mbits/sec 0 3.04 MBytes
[ 4] 4.00-5.01 sec 112 MBytes 941 Mbits/sec 0 3.04 MBytes
[ 4] 5.01-6.00 sec 111 MBytes 939 Mbits/sec 0 2.32 MBytes
[ 4] 6.00-7.01 sec 112 MBytes 937 Mbits/sec 0 2.50 MBytes
[ 4] 7.01-8.00 sec 111 MBytes 939 Mbits/sec 0 2.64 MBytes
[ 4] 8.00-9.00 sec 112 MBytes 939 Mbits/sec 0 2.76 MBytes
[ 4] 9.00-10.00 sec 112 MBytes 938 Mbits/sec 0 2.86 MBytes
[ 4] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver
iperf Done.
