Hard Drive
Hello
is it possible to access the Vero 4 K from the PC? Would like to drag films to the hard drive that I have connected to the Vero 4K. I have already tried it via the Ip address of the vero 4K and via an FTP program, but I cannot see any disks that are connected. Would be grateful for every tip. Lg holymann
Thank you in advance
Assuming your PC runs Windows then you would need to install the Samba Server from the App Store (in MyOSMC menu).
Ok thanks.
can i do this directly in the vero menu?
Thank you again lg Holymann
Yes, MyOSMC :wink:
An FTP and Samba server can be found under My OSMC -> App Store.
Thank a lot
LG Holymann
