I am trying to install OSMC on a 4GB card through DietPi (Based on Raspbian) and using RCA cables instead of HDMI. I’ve downloaded the latest image and extracted it.
Then I wrote the image with dd command. That created a 320 mb fat32 formatted partition on the memory card. No second ext4 partition yet.
I tried booting up that card but nothing happened. Added sdtv_mode=2 to config.text, still nothing. What could be going wrong?
I am using 3b+ and yes I did pick up the right version. The file is name OSMC_TGT_rbp2_20191118.IMG.gz which I think is the the correct one.
When I installed the image it only created one partition, when there are typically two, is it supposed be that way?
And my config.txt file in root of that first partition only had 3 parameters at default which were gpu_mem framebuffer and one more , when DietPi or libreELEC has many, could this be a problem?
I am using the same RCA cables with DietPi so the cables are not faulty.
Could you for the time of the initial setup switch to using a HDMI connection?
That’s the problem, i don’t have access to any HDMI display. So i cannot confirm whether the install is broken in some way or that it’s the configuration of output that is messed up.
Well you could try to press blindly ENTER to start the installation (you will see the green light flashing for action). After initial installation is done you could again try to change the config.txt.
I tried that couple of times and there was no green light flashing and it didn’t create a new partition. I just can’t figure out what the problem could be.
This is my config.txt on a running OSMC install for 3B+ which is usually using hdmi but if I boot it with no hdmi connected it displays fine through cvbs.
This time the green light kept blinking 3 times after regular intervals, the same thing happened when i had copied DIetPi config to OSMC root. I left it on for 15 minutes and it still hasn’t created any new partition.
I think the issue might not be the video output but that the OS just isn’t loading.
Just installed NOOBS lite on that same memory card with same tools. On first boot it didn’t show anything either but i did create new partitions. On second boot i kept hitting 3 on keyboard for PAL and it worked.
The only thing i did different this time was that instead of boot partition being created by dd or gnome_disks, it was done by me with fdisk and mkfs. And just copy pasted the files afterwards.
Can i do the same with OSMC? Create new partition 400MB in size with fat32 filetype and paste all the OSMC files? Could that work?
