Hoping someone can help me troubleshoot. This is a regular Vero 4k.
File that I’m trying to playback is large – doesn’t really have any trouble buffering and plays back initially OK but eventually just stops playback and returns me to the menu. I’m not able to FF/RW or skip chapters to the resume point (I just get the blue spinning ball indefinitely.)
File is located on my UnRaid server. Everything is hard wired and I’ve got my NFS shares mapped on OSMC via fstab.
Here’s mediainfo:
General
Unique ID : 152450380209161917298791922389079060333 (0x72B0E00EEDEC85A5A29ED01589446F6D)
Complete name : .mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 35.2 GiB
Duration : 1 h 55 min
Overall bit rate : 43.4 Mb/s
Movie name : 4K
Encoded date : UTC 2018-04-14 22:33:47
Writing application : mkvmerge v22.0.0 (‘At The End Of The World’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
IsTruncated : Yes
Video
Format : HEVC
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Writing library : ATEME Titan File 3.8.13 (4.8.13.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / ES Matrix / Core
Codec ID : A_DTS
Bit rate mode : Variable / Constant / Constant
Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s
Channel(s) : 8 channels / 7 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless / Lossy / Lossy
Title : DTS-HD MA 7.1
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Title : English (SDH)
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Title : Spanish (Latin American)
Language : Spanish
Default : No
Forced : No
Text #3
Format : PGS
Title : French
Language : French
Default : No
Forced : No
Thoughts?
