Hello. for the 4k+ which standard of cable is provided in the box?
Can I know full specs and which resolution formats are supported.
I want to understand if I need to buy an additional cable to get the best from the device.
They are High Speed cables which handle up to 4k60Hz. If you need a longer cable Amazon Basics are good value.
thanks. How long is the cable in the box? 1m?
@sam_nazarko can tell you what he’s currently shipping. I think mine was about 4ft.
1 meter is fine for me
It’s 0.8m. I’ve given you some details in the ticket you opened; but it’s the same advice as @grahamh gave.
thanks. I replied to the ticket.
cheers
