My TV recognizes a CEC signal after I start OSMC (it’s displayed as Kodi on my TV), but the TV remote still doesn’t work and the “Kodi” label vanishes after a few seconds. Here’s a new log: New Logs
Now my TV isn’t showing Vero as Kodi anymore on boot. Tried disabling/enabling CEC adaptor in Kodi and setting HDMI port to 2 (that’s the port Vero is connected to).
I was going to email Gerald today, but I see he beat me to the mark and replied to the post quite promptly. I’ll send him an email with some specifics. In the interim, can you try connecting to another non Sony TV and letting me know if the issue persists? This may narrow things down.
I use two Vero 2 box.
Prod Vero (not updated in avril
Test Vero (with latest avril update from saturday)
I try a minimal installation, modify only network settings and install samba and ssh. No data in library. Test with two TV
First TV: Toshiba 26EL834G Firmware 1.05
CEC don’t work,
I test with the prod Vero2 CEC don’t work also
Second : Sony Bravia KDL55HX920 Firmware PKG4.027EUA-0104
CEC dont work for test Box, work’s fine with the prod box
It’s work for me on the Sony TV. i found some errors messages in the log
And in the Debian update this error message
Hmm. The package shipped with a symbolic link /lib/modules/3.10.101-5-osmc/source
However, I can not read the target: Aucun fichier ou dossier de ce type
Therefore, I am deleting /lib/modules/3.10.101-5-osmc/source
Merci Sam, your team (and kszaq) for your work
Michael
PS: I think tomorrow i update my “prod” vero. With CEC enabled i can take the risc …
This morning i updated my prod box, and the first time it’s works fine.
After reboot, no more.
I try a lot of the things, sometime it’s works, sometime no.
Also for prod box , also for test box.
In the log
CEC write failure <
and nothing more.
I also take a look into my (Sony Bravia) TV.
I can modify some settings, but I’m not sure that it’s really important. I know “nothing” from CEC protocol.
I need one or more test cases, try to separate OSMC , TV Sony issues.
My (first) question:
When I connect two Vero Box (same OS Level, different host names) to the same TV, the TV say that it was two different boxes ( My Sony TV tell me, when I connect the two box HDMI 1 → Kodi, HDMI 2 → KODI) ?
I hope you can understand my questions, I’m searching to make for me a to do list.
Michael
PS: Perhaps better to split the question in another thread
Does turning off the device and TV help remedy the situation? Can you let me know the exact sequence of steps to replicate the problem?
If you can do so on the test box, rm -rf .kodi/ which will remove any customisations (incl peripheral settings), and see if this persists. If it does, then it rules out any local issues being at play, and we can delve deeper.
On the plus side, I’m glad CEC now works on your TV set, even if it doesn’t work for a reboot. It means we’re making progress. I have a couple of changes which I’ll get built, and I’ll let you know when there’s another build to test.
