I want to achieve that I can control all devices with a single (LG) remote control via HDMI-CEC. But this only works partially. What i’ve tried so far:
Set up the “Denon AVR-X1400H” in the “LG OLED 55C7” as AVR:
-> AVR and TV control works but not the Vero box.
Set up the “Denon AVR-X1400H” in the “LG OLED 55C7” as “other device”:
-> AVR, TV and Vero 4K+ control works but not within the Smart TV Apps (Netflix/Amazon),
because the HDMI-CEC signal is transfered from the TV to the Vero and back to the AVR.
I have a C7 + X4400H + Vero4k and it works for me. Enabled HDMI-CEC on the AVR and enabled SIMPLINK or whatever it’s called on the LG TV (it’s under General in settings). I can control the Vero with it and the Netflix app still works. I have not used that weird wizard setup thingy on the LG that asked “hey do you want to control your AVR with the remote?”.
HDRpotato, as far as i remember you have eARC on your AVR, not the 1400 and my 2400h. Maybe thats why it works better
I can also only control the receiver and TV. For the Vero i have to use its own remote and still use the AVRs remote to select “Media Player” for the Vero menu to show up
