Hi.
After the upgrade to Kripton
the HDMI CEC a lot of time doesn’t functioned
I power on the tv but i cannot use tTV remote control for command raspberry Pi 2
the screen go to the left and to the right if i use the left or right arrow
I tried a lot of time to power off and power on the tv and then to HDMI CEC seems functioned.
Thanks a lot
Bye
The next update will have some fixes for cec.
Thanks for replay
Bye
My CEC stops but my fix is just change Video input to another then back again
It’s true.if i tried to change input device (for example tv) and return to raspberry input (HDMI 1) the cec seems to work again
Don’t know if this is the right topic but I’m also experiencing CEC issues after Krypton update: when I press a key on the remote, OSMC repeats the selected command twice (e.g. I press the down arrow once and it moves two “tiles” down", I press the “back” key and it goes two menus back). Are these issues also being fixed by the next update?
Once I reverted to Kodi Jarvis the issues was gone.
Thank you
Settings>system>input>peripherals>cec may have an option for repeat keypress suppression
I tried with no luck the following settings (libcec 4.0.2):
(This setting works on Jarvis and libcec 3xx)
Remote button press delay before repeating (ms): 300
Remote button press repeat rate (ms): 0
Remote button press release time (ms): 0
Remote button press delay before repeating (ms): 800
Remote button press repeat rate (ms): 100
Remote button press release time (ms): 100
Any advice? Jarvis works like a charm…
i have the same issue: most commands are repeated twice :-/
i tried librelec 8.0 (krypton 17) with the same issue. couldn’t find any settings in libcec (or osmc pi settings) to fix this
Tried with several configurations with no luck… is there anyone that could help us? Thanks
In system/input/peripherals/cec set the repeat rate to, say 150ms.
I tried different settings (even repeat rate higher than delay) no luck so far
Also in March update there’s the same problem with HDMI CEC
Bye
Hi, is there any news on this issue?
It seems to be related to libcec 4 as many users fixed the problem reverting to OSMC based on Kodi 16.1… any advice?
The issue should be fixed with the next update.
Thank you very much! Do you mean the april OSMC update or the next libcec update? Is there a release plan? Thanks
After last update my remote control by libcec is broken and don’t work anymore.
How can I fix it?
P.S. It’s false alarm I just unpluged HDMI and power cabels couple times and OSMC work now again.
I mean the april update.
I installed the april update from scratch on a spare SD card (well, I installed the march build and then updated), the problem is still there…
I’ll try with the april disk image as soon as it’s available and let you know
Ok. Then this could be a different problem.
I didn’t have time to test it myself.
You could still post some debug logs that demonstrate it then.
Might be helpful.
