maybe someone has a hint. I have bought a HDMI splitter which automatically switch to a “new” signal. So if i turn on my Nintendo Switch or my Sat Receiver it will automatically switch to that channel. When i turn them off it should switch again to an active HDMI signal. Since the Vero4k is running 24x7 the signal should be always there, but it does not switch to it. I have connected it to channel 1 since in the handbook it is mentioned that it will automatically switch to that per default. But this does not work either.
Could it be that the HDMI signal of the Vero4k is suspended when i switch to another channel? In the past i have used the the sleep mode and the device automatically waked up once i switched on the TV. But with the new splitter it gave quite some problems therfore i have de-activated it.
ok, I found, I have Vero 2, my problem is that I have an hdmi splitter which auto switch input when signal is detected, what I want is that when osmc go to sleep, is that hdmi signal is off, is it possible?
