Hi guys,
I hope all are keeping well.
I’ve just a small issue that I don’t even have a clue on where to begin trying to fix.
For some strange reason, the 3.5mm headphone audio jack on my Vero 4k + simply just completely stopped working at all.
I’ve tried all the audio cables & headphones with different devices and they are all working. So I know the audio equipment it working perfectly. If anyone has any ideas that would be greatly appreciated.
Kindly see the logs link below:
https://paste.osmc.tv/nepafigiro
Many thanks in advance & stay safe.
It’s a CVBS output.
Are you using a CVBS cable?
Are you talking about just the GUI sounds?
Play GUI sounds: Never ===> Default: Only when playback stopped
Oh it’s a CVBS output, I was thinking it was a standard 3.5mm audio jack Ahah. Well, that’s solved that issue. Although it’s rather strange that before it was working perfectly using a 3.5mm headphone…
Not too sure if I have set something incorrectly, but for some reason, there is a white noise/static in the background while playing media. This is with headphones plugged directly into the TV, I had also never experienced this before. In any case, all assistance is always greatly appreciated.
Nope, GUI sounds have been disabled.
Will
Some standard (TRS) headphone jacks work, some don’t. The TRRS jacks on headsets will not work.
