Hy i need help.
I have osmc installed on raspberry pi2 and after a shuting down of the raspberry the screen apears like this http://bit.ly/1D5zzw7
can you help me?
I dont have a keyboard connected to the raspberry and i dont see why i have to.
I cant connect ssh or ftp.
Is there an issue with leaving the thing running? It uses almost no power when idling. Someone on Kodi forum calculated it to be like $2/year…
I havê no issue with that. Just happened.
I only dont understand why i must have a keyboard connected to it so i can power it on.
What you show in your screenshot is not normal at all - it is dropping to an emergency recovery console.
Have you installed any additional software or made changes to the system configuration outside of Kodi ?
What command are you typing to shut down, or are you doing so from the Kodi menu ?
When you shut down a Pi it should go to a black screen with no HDMI signal. Once this happens you have to manually disconnect the power and reconnect it to start up again.
A keyboard is not required to shut down or start up a Pi.
Ive shutdown in kodi. Then the next time ive plug it in this screen showed up.
This is not normal at all.
What can i do?
Get a keyboard?
You mean, this showed up while starting?
You could attach a keyboard temporarily to analyse the cause of this and detach it afterwards
Ive shut down the raspberry on thebpower off button that Kodi has
