Alien0
1
Hi guys
I’m updated on the latest kodi version on RPi 2
Osmc was working well since the update
This problem happened after I changed the sdram from 400 to 600
Got this message when attempted to reboot
Waiting for root filesystem device /dev/sda1
Can’t ssh
Appreciate your help
Plug the SD card and change the value back in config.txt
Put it back in the Pi keep fingers crossed and plug in power
Alien0
3
ok…going to try…fingers crossed:cold_sweat:
sdram 600 is too high for a Pi 2. Changing it back in config.txt should fix it.
Alien0
5
Thanks guys for that quick fix:relaxed:
I increased the sdram to see if some hevc files would play better but you’re right, its too high for Pi 2
Have a great day:slightly_smiling:
450 which now is the normal in OSMC should be save
