I’m in trouble with my Vero 4k.
On startup, I can see that Open SSH server failed to launch = 1st problem
Next, my skin Aeon MQ7 start as if it was just installed… and black screen.
So, I can’t use ssh and I can’t exit to access shell…
FInally, I managed to exit kodi using Yatse, then log and fix the pb with ssh server (I made a mistake in configuring it… my bad)
On restart, I had the same pb with Aeon MQ7, so I restore my backup manually, then it seems to work fine (except many errors in log, related to bugs I think…)
