Hello I have a Raspberry pi b+ and the latest version of osmc. I would like to have a hotspot wifi. I plugged an edimax dongle on the Raspberry, then I went to the network parameter, I selected “ethernet to wifi” option and clic on enable. The Following message appears : “error enabling hotspot see log for detail”. Is anybody knows what is the problem? Do I missed Something in the configuration? Thanks you very much in advance.
Might be the driver doesn’t support nl80211
Hello,
What is the nl80211? You mean that the dongle driver does not support that?
Thank you
nl80211 is required by connman to provide hotspot functionality and that need to be supported by the dongle driver
What is connman?
Connman is the network manager of OSMC
So ? What can I do ? Can you help me please ?
Thank you very much.
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
- publish the provided URL from the log set upload, here
As pointed out fzinken, nl80211 is not supported by the driver.
Please confirm the dongle is a Edimax EW-7811Un ?
Thanks Tom
Yes the dongle is a Edimax EW-7811U
Do I have to buy another one?
This may help:
https://jenssegers.com/43/realtek-rtl8188-based-access-point-on-raspberry-pi
Sorry but I’m not in a position to test, as I do not have the wifi dongle.
I would do a backup before trying this and it also probably worth waiting to see if @sam_nazarko has any thoughts.
Thanks Tom.
The driver doesn’t implement the necessary interface for tethering.
The upstream driver does, but it’s not very good.
Hello,
So what can I do? Do I have to buy another dongle to manage to do my wifi hotspot?
Thank you
