How can i Setup IR remote with omsc + raspberry pi installation
HI
i have one TSOP 38238 which is almost same pinout like TSOP44… TSOP48…
Thanks & Regards,
Ben
LIRC GPIO works out of the box on Pi
HI
thanks for the reply. How can i map my remote to RPI.
Did you check out remotes under my OSMC and the Wiki?
finaly i have created /home/osmc/lircd.conf and browsed this from OSMC remote configuration menu and rebooted OSMC server.
after that not all keys are working,but some of them are mapped correctly
HI
Thanks all…
i have successfully mapped my remote and it’s working now
