What settings are in mpd.conf?
This will need to update to config here to get sound.
Thanks Tom.
Thanks Tom.
Hi Tom,
Am right at bottom of learning curve here. I assume the config file you need to start is /etc/mpd.conf so here its is:-
osmc@Restaurant_Player:/etc$ cat mpd.conf
# An example configuration file for MPD.
# Read the user manual for documentation: http://www.musicpd.org/doc/user/
# or /usr/share/doc/mpd/user-manual.html
# Files and directories #######################################################
# This setting controls the top directory which MPD will search to discover the
# available audio files and add them to the daemon's online database. This
# setting defaults to the XDG directory, otherwise the music directory will be
# be disabled and audio files will only be accepted over ipc socket (using
# file:// protocol) or streaming files over an accepted protocol.
music_directory "/var/lib/mpd/music"
# This setting sets the MPD internal playlist directory. The purpose of this
# directory is storage for playlists created by MPD. The server will use
# playlist files not created by the server but only if they are in the MPD
# format. This setting defaults to playlist saving being disabled.
playlist_directory "/var/lib/mpd/playlists"
# This setting sets the location of the MPD database. This file is used to
# load the database at server start up and store the database while the
# server is not up. This setting defaults to disabled which will allow
# MPD to accept files over ipc socket (using file:// protocol) or streaming
# files over an accepted protocol.
db_file "/var/lib/mpd/tag_cache"
# These settings are the locations for the daemon log files for the daemon.
# These logs are great for troubleshooting, depending on your log_level
# settings.
# The special value "syslog" makes MPD use the local syslog daemon. This
# setting defaults to logging to syslog, otherwise logging is disabled.
log_file "/var/log/mpd/mpd.log"
# This setting sets the location of the file which stores the process ID
# for use of mpd --kill and some init scripts. This setting is disabled by
# default and the pid file will not be stored.
pid_file "/run/mpd/pid"
# This setting sets the location of the file which contains information about
# most variables to get MPD back into the same general shape it was in before
# it was brought down. This setting is disabled by default and the server
# state will be reset on server start up.
state_file "/var/lib/mpd/state"
# The location of the sticker database. This is a database which
# manages dynamic information attached to songs.
sticker_file "/var/lib/mpd/sticker.sql"
# General music daemon options ################################################
# This setting specifies the user that MPD will run as. MPD should never run as
# root and you may use this setting to make MPD change its user ID after
# initialization. This setting is disabled by default and MPD is run as the
# current user.
user "mpd"
# This setting specifies the group that MPD will run as. If not specified
# primary group of user specified with "user" setting will be used (if set).
# This is useful if MPD needs to be a member of group such as "audio" to
# have permission to use sound card.
#group "nogroup"
# This setting sets the address for the daemon to listen on. Careful attention
# should be paid if this is assigned to anything other then the default, any.
# This setting can deny access to control of the daemon. Choose any if you want
# to have mpd listen on every address. Not effective if systemd socket
# activation is in use.
# For network
bind_to_address "localhost"
# And for Unix Socket
#bind_to_address "/run/mpd/socket"
# This setting is the TCP port that is desired for the daemon to get assigned
# to.
#port "6600"
# This setting controls the type of information which is logged. Available
# setting arguments are "default", "secure" or "verbose". The "verbose" setting
# argument is recommended for troubleshooting, though can quickly stretch
# available resources on limited hardware storage.
#log_level "default"
# If you have a problem with your MP3s ending abruptly it is recommended that
# you set this argument to "no" to attempt to fix the problem. If this solves
# the problem, it is highly recommended to fix the MP3 files with vbrfix
# (available as vbrfix in the debian archive), at which
# point gapless MP3 playback can be enabled.
#gapless_mp3_playback "yes"
# Setting "restore_paused" to "yes" puts MPD into pause mode instead
# of starting playback after startup.
#restore_paused "no"
# This setting enables MPD to create playlists in a format usable by other
# music players.
#save_absolute_paths_in_playlists "no"
# This setting defines a list of tag types that will be extracted during the
# audio file discovery process. The complete list of possible values can be
# found in the mpd.conf man page.
#metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
# This setting enables automatic update of MPD's database when files in
# music_directory are changed.
#auto_update "yes"
# Limit the depth of the directories being watched, 0 means only watch
# the music directory itself. There is no limit by default.
#auto_update_depth "3"
# Symbolic link behavior ######################################################
# If this setting is set to "yes", MPD will discover audio files by following
# symbolic links outside of the configured music_directory.
#follow_outside_symlinks "yes"
# symbolic links inside of the configured music_directory.
#follow_inside_symlinks "yes"
# Zeroconf / Avahi Service Discovery ##########################################
# If this setting is set to "yes", service information will be published with
# Zeroconf / Avahi.
#zeroconf_enabled "yes"
# The argument to this setting will be the Zeroconf / Avahi unique name for
# this MPD server on the network.
#zeroconf_name "Music Player"
# Permissions #################################################################
# If this setting is set, MPD will require password authorization. The password
# can setting can be specified multiple times for different password profiles.
#password "password@read,add,control,admin"
# This setting specifies the permissions a user has who has not yet logged in.
#default_permissions "read,add,control,admin"
# Database #######################################################################
#database {
# plugin "proxy"
# host "other.mpd.host"
# port "6600"
# Input #######################################################################
input {
plugin "curl"
# proxy "proxy.isp.com:8080"
# proxy_user "user"
# proxy_password "password"
# Audio Output ################################################################
# MPD supports various audio output types, as well as playing through multiple
# audio outputs at the same time, through multiple audio_output settings
# blocks. Setting this block is optional, though the server will only attempt
# autodetection for one sound card.
# An example of an ALSA output:
audio_output {
type "alsa"
name "My ALSA Device"
# device "hw:0,0" # optional
# mixer_type "hardware" # optional
# mixer_device "default" # optional
# mixer_control "PCM" # optional
# mixer_index "0" # optional
# An example of an OSS output:
#audio_output {
# type "oss"
# name "My OSS Device"
# device "/dev/dsp" # optional
# mixer_device "/dev/mixer" # optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
# type "shout"
# encoder "vorbis" # optional
# name "My Shout Stream"
# host "localhost"
# port "8000"
# mount "/mpd.ogg"
# password "hackme"
# quality "5.0"
# bitrate "128"
# format "44100:16:1"
# protocol "icecast2" # optional
# user "source" # optional
# description "My Stream Description" # optional
# url "http://example.com" # optional
# genre "jazz" # optional
# public "no" # optional
# timeout "2" # optional
# mixer_type "software" # optional
# An example of a recorder output:
#audio_output {
# type "recorder"
# name "My recorder"
# encoder "vorbis" # optional, vorbis or lame
# path "/var/lib/mpd/recorder/mpd.ogg"
## quality "5.0" # do not define if bitrate is defined
# bitrate "128" # do not define if quality is defined
# An example of a httpd output (built-in HTTP streaming server):
#audio_output {
# type "httpd"
# name "My HTTP Stream"
# port "8000"
# bind_to_address "0.0.0.0" # optional, IPv4 or IPv6
# max_clients "0" # optional 0=no limit
# An example of a pulseaudio output (streaming to a remote pulseaudio server)
# Please see README.Debian if you want mpd to play through the pulseaudio
# daemon started as part of your graphical desktop session!
#audio_output {
# type "pulse"
# name "My Pulse Output"
# server "remote_server" # optional
# sink "remote_server_sink" # optional
# An example of a winmm output (Windows multimedia API).
#audio_output {
# type "winmm"
# name "My WinMM output"
# device "Digital Audio (S/PDIF) (High Definition Audio Device)" # optional
# or
# device "0" # optional
# An example of an openal output.
#audio_output {
# type "openal"
# name "My OpenAL output"
## Example "pipe" output:
#audio_output {
# type "pipe"
# name "my pipe"
# command "aplay -f cd 2>/dev/null"
## Or if you're want to use AudioCompress
# command "AudioCompress -m | aplay -f cd 2>/dev/null"
## Or to send raw PCM stream through PCM:
# command "nc example.org 8765"
# format "44100:16:2"
## An example of a null output (for no audio output):
#audio_output {
# type "null"
# name "My Null Output"
# mixer_type "none" # optional
# If MPD has been compiled with libsamplerate support, this setting specifies
# the sample rate converter to use. Possible values can be found in the
# mpd.conf man page or the libsamplerate documentation. By default, this is
# setting is disabled.
#samplerate_converter "Fastest Sinc Interpolator"
# Normalization automatic volume adjustments ##################################
# This setting specifies the type of ReplayGain to use. This setting can have
# the argument "off", "album", "track" or "auto". "auto" is a special mode that
# chooses between "track" and "album" depending on the current state of
# random playback. If random playback is enabled then "track" mode is used.
# See <http://www.replaygain.org> for more details about ReplayGain.
# This setting is off by default.
#replaygain "album"
# This setting sets the pre-amp used for files that have ReplayGain tags. By
# default this setting is disabled.
#replaygain_preamp "0"
# This setting sets the pre-amp used for files that do NOT have ReplayGain tags.
# By default this setting is disabled.
#replaygain_missing_preamp "0"
# This setting enables or disables ReplayGain limiting.
# MPD calculates actual amplification based on the ReplayGain tags
# and replaygain_preamp / replaygain_missing_preamp setting.
# If replaygain_limit is enabled MPD will never amplify audio signal
# above its original level. If replaygain_limit is disabled such amplification
# might occur. By default this setting is enabled.
#replaygain_limit "yes"
# This setting enables on-the-fly normalization volume adjustment. This will
# result in the volume of all playing audio to be adjusted so the output has
# equal "loudness". This setting is disabled by default.
#volume_normalization "no"
# Character Encoding ##########################################################
# If file or directory names do not display correctly for your locale then you
# may need to modify this setting.
filesystem_charset "UTF-8"
# This setting controls the encoding that ID3v1 tags should be converted from.
id3v1_encoding "UTF-8"
# SIDPlay decoder #############################################################
# songlength_database:
# Location of your songlengths file, as distributed with the HVSC.
# The sidplay plugin checks this for matching MD5 fingerprints.
# See http://www.c64.org/HVSC/DOCUMENTS/Songlengths.faq
# default_songlength:
# This is the default playing time in seconds for songs not in the
# songlength database, or in case you're not using a database.
# A value of 0 means play indefinitely.
# filter:
# Turns the SID filter emulation on or off.
#decoder {
# plugin "sidplay"
# songlength_database "/media/C64Music/DOCUMENTS/Songlengths.txt"
# default_songlength "120"
# filter "true"
Canât see [code] brackets anywhere. Clearly different style here so please put me right in due course.
Does this help at all?
Regards,
Budge
Iâve only setup MPD with raspbian on and the defaults worked from hdmi, but some googling I think this should allow you get the sound via hdmi.
change:
audio_output {
type "alsa"
to:
audio_output {
type "alsa"
device "hw:CARD=AMLM8AUDIO,DEV=0" # optional
If that doesnât work try:
device hw:CARD=AMLM8AUDIO,DEV=1
If that doesnât help, I would ask JF if they have any thoughts.
Thanks Tom.
Hi Tom,
Many thanks for the suggestions and will try what you suggest.
It is clear meanwhile that I still have much to learn so will tinker a bit more and not waste more of your time until I know more. Very many thanks.
One last question on this. If I mess up badly, is there any way to restore or re install Vero 4K system rather than uninstall unwanted stuff I have installed.
Hi many thanks. Perfect.
