I have read but can’t seem to find how to or if I can.
1- If I just want to start with a fresh install of Kodi vers 17.xx what would I need to do to accomplish this?
2- Would reinstalling the OSMC image from USB accomplish this or is this the right way?
Thanks for the help.
- Would do this but reinstall osmc completely
Instead you can stop Kodi and move the userdata directory away
2- meaning the OSMC USB flash I made with the OSMC installer would reinstall OSMC completely and Kodi 17.xx?
I have access through samba shares and can move the user directory, but what will happen on reboot regarding Kodi? I messed up some Kodi add ons so want to start with clean kodi slate.
- yes
If you move the Kodi directory away it will be regenerated
Great thanks Sam.
I have to tell you that you and your team are simply amazing from product to support I have never encountered anything so professional and supportive.
Your product is top notch and will only continue to get better with future updates. :*)
