On my LAN I have a “noisy” network device that I’d like to filter out on my Kodi devices (and no, at least for now I can’t solve the issue at the source or from network switch side).
What is the intended way to add some rules to the existing firewall in OSMC (Kodi 19, Vero4k+) ?
I still use iptables, myself.
Thanks Tom.
Thanks.
Where do you save the rules to be loaded at boot time?
I use iptables-peristent
sudo apt-get install iptables-persistent
To save (you will be prompted on first install, but to save changes):
sudo netfilter-persistent save
To make the rules restore on startup:
sudo systemctl enable netfilter-persistent
Thanks Tom.
