I am really enjoying the freshly OSMC’d ATV1 + Crystal HD.
It is running faster than ever before using OE and has brought it back from redundancy…
Thank you to all involved.
I am having problems with the Colour Space. Too much RED.
I am outputting from ATV1 in Composite into a YUV Component to RGB Scart converter then into the non-RGB Scart input of a Toshiba CRT. Sadly only one input is RGB Scart which is taken by the Virgin Media box which produces realistic colours.
If you are wondering why I bother using the Converter and not straight into Composite Scart it is because the signal is amplified and has less noise.
I was wondering if there is a command to ssh in order to change the video profile.
I have looked at the video card info but cannot see anything relevant: ftp://download.nvidia.com/XFree86/Linux-x86/1.0-7667/README.txt
Suggestions much appreciated.
