How to edit x11 conf
Continuing the discussion from Hard disk installations now possible:
so connect it already;-) find out its ip (in your router’s interface of connected devices) then open a terminal on your desk/laptop, then type:
ssh osmc@ip.ad.dr.es
the passwd is osmc
then
sudo vi /etc/X11/xorg.conf
hth:-)
I recommend nano, which ships with OSMC by default, for new users, not vi
it is not connected to the internet, because I do not have a long ethernet cable that can go 2 floors.
I’ll figure something out.
so carry it upstairs & plug it in there:-)
