I’m trying to enable HotSpot on an RPi2 using the OSMC, without success.
Using the GUI I’m getting denied using command line getting “Error enabling ethernet tethering: Permission denied”
I’ll appreciate some guidelines how to…?
I’m trying to create a local network using the RPi without connectivity to ethernet in any way.
Any help will be appreciated.
ethernet to wifi tethering not working. I downloaded the latest version. 27-setp.
Lan is getting valid IP and wirless device are also able to connect “osmc_wifi” but no network. Pls let me know how to fix.
Great… Working now…
Pls help how to enable PPoe support. More important the dongle i am using is 433Mb/s support but in tethering it is conncet to 72Mb/s per second. Very limited .
Macbook is getting disconnected after few seconds… Due signal issue.
Donlge : AC600 Wireless Dual-Band Mini USB Adapter
We don’t have any plans at this point in time to add built in support for PPPoE - this is far too niche a facility for a Media center to make the development effort worthwhile when time is better spent elsewhere.
However because the system is based on Debian Jessie using connman as the network manager there is probably a way to set it up manually yourself if you do some research.
Hi all thanks for the notes but still this doesn’t solve the question I have because I’m still unable to set up a Hotspot that i can connect using my iPhone or any other device on the network what I would like to see is a hotspot generated on the raspberry pie that I can access and connect to without having ethernet connected at all.
Any user manual or guidelines how to generate a hotspot from the raspberry pie
These last 2 questions are relevant to my problem.
I have Alfa 5ghz ac wifi usb adapter which works great on PI 1b with OSMC as Hotspot and thanks millions guys for making this so easy to set up with your fantastic GUI interface…
the problem is - I want it to be 5ghz at all times (it only sets itself at 72Mbps at moment) and also it is an addition for existing 5ghz router and is in smallish room and I want to turn down it*s output signal strength to very low… what folder would I find those settings to change… thanks
